Show only
Search instead for
I think everyone has the same issue with 2008 and we haven't found any workarounds other than clearing the offset of each subassembly. Hopefully it will be fixed in SP1.
wrote in message news:5632446@discussion.autodesk.com...
The other workaround for copying within the drawing is to copy with no displacement. Then use a move command to move the new sub-assembly. We are aware of the issue.
Nick
I get both of those and a few others ... Dana the one that you link to does it also do it to the standard sub-assemblies within 08 that are already .NET? I'm getting it to the stock 08 sub's and can't figure out why.
