Civil 3D Forum
Civil Design Companion Install
6 REPLIES 6
187 Views, 6 Replies
I'm trying to install the Civil Design Companion for use with LDT 2006. In previous releases, this has been an add-on to LDT, but I believe it’s now available as a companion product to Civil 3D. I've downloaded both LDT 2006 and Civil 3D 2006 via my ADN membership, but I’ve been unable to find the Civil Design Companion. I found the Survey module just fine. Does anyone have any info on this?
Andy
6 REPLIES 6
The 2005 version is the only one available for ADN subscribers.
wrote in message news:5047094@discussion.autodesk.com...
previous releases, this has been an add-on to LDT, but I believe it's now
and Civil 3D 2006 via my ADN membership, but I've been unable to find the
Andy
Hi Andy,
The Civil 3D companion is nothing more or less than a Land Desktop 2006
which recognises the Civil 3D licence.
Hence to provide for a seperate download doesn't make much sense.
Laurie Comerford
CADApps
www.cadapps.com.au
Andy
OK, thanks, this is starting to make sense. I've avoided the issue until now, but I need to access some Civil Design components (Pipes, etc.) -- preferably in the 2006 interface. As an ADN member, what do I need to do to access Civil Design? (I have an item for the Civil Design workspace in LDT 2006, but nothing happens when I click it.) Do I need to access Civil Design through Civil 3D?
Hi Again Andy,
You can't access Civil Design from Civil 3D.
Civil Design MUST sit on top of Land Desktop as it uses the Land Desktop
DTMs and Alignments.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:5047661@discussion.autodesk.com...
through Civil 3D?
Understood. But is there a way to get the Civil Design components into LDT if they aren't provided in the LDT or C3D versions from the ADN website?
Hi Andy,
This is a question which you should take up via your ADN membership.
I know someone from our company obtained a copy of Civil Design, but for me
it merely turned up on the computer, so I don't know what happened.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:5048314@discussion.autodesk.com...
Rail Community
