Civil 3D Forum
Civil 3D Volumes dashboard, sort columns alphabetically?
71 REPLIES 71
Message 1 of 72
wilsonm2000
7203 Views, 71 Replies
Hi
Is there a way I can sort the columns in the dashboard alphabetically?  Normally you just click the title in these windows to toggle the way it sorts it, but you cannot do that with this tool.  Its making my cut/fill report look messy, as the surface volumes are not in any order.
MArtin
71 REPLIES 71
Message 61 of 72
neilyj666
in reply to: wilsonm2000
@FrankHuang For me it is more important to be able to sort the boundaries under a volume surface and not just by pick order as additional boundaries may be required that split an existing boundary and I typically want to rename the boundaries to reflect, for example, the earthworks phasing.
In actual fact, I find the volumes dashboard quite clunky in its current form and I prefer to divide my project up using Parcels/Plots and run the parcel volume report in the toolbox. However the output from this report is painful to use for anything practical so I have had to write some VBA code in Excel to process the outputs into something more usable.
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 62 of 72
tomas_hultman
in reply to: FrankHuang
@FrankHuang
The sorting function for me is the number one priority.
After that comes functionality for dynamic linking of surfaces and what they represent.
If you could define prerequisites for volume surfaces, such that they automatically subtract certain volumes and present the excavation volume of a certain material (morraine, clay and so on).
See the attatched picture. To define the volumes of each layer independently, would be terrific.
I know this can be done with corridors/sections and so on, but it is not practical at all for residential, industrial establishments.
Sections are mostly suited for longer streches of roads.
Best regards, Tomas
Message 63 of 72
neilyj666
in reply to: tomas_hultman
@tomas_hultman I totally agree that there needs to be a better workflow for this use case as corridors/sections aren't always appropriate and in my experience have two be set up in two mutually perpendicular orientations to get a better assessment (and typically with a very close section spacing)
Message 64 of 72
wes.sheffer
in reply to: neilyj666
I'd also like to see more sophistication in computing volumes when comparing more than two surfaces.
In particular, I've had to follow some pretty inelegant workflows to compute cut and fill below a floodplain surface (or elevation) while discarding cut and fill that occurs above the floodplain surface.  It would be nice to have a built-in way to use a third surface as a vertical boundary on the computation.
Message 65 of 72
jcushing
Getting the columns to stay in the order of pick sequence would be a good first step.
But it would also be useful if we had the ability to sort when necessary.
Message 66 of 72
Well, it's been 12 years now, so I don't think Autodesk are in any rush to go over the original code (they probably don't know how to edit the code) 😉
Message 67 of 72
neilyj666
There are many aspects in the volumes computation area that Civil 3D is way behind on....we can't even report the cut area and fill area without jumping through a load of analysis and table creation palaver
Message 68 of 72
autoMick
My priority is alphanumeric sorting. Pick order would be good too, but not as flexible as the ability to rename/sort as required.
Civil3d user in Australia since 2012.
Message 69 of 72
FrankHuang
@autoMick @wilsonm2000 @neilyj666 @tomas_hultman I am looking for a sample drawing for testing purpose.
Is there a drawing can be shared with me?
Frank Huang
Autodesk Civil 3D Product Owner
"https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png"
Message 70 of 72
ebu6N7Y5
Why not just make a drawing of your own with multiple surfaces and work from there? It won't make a difference.
Message 71 of 72
neilyj666
@FrankHuang I try and avoid the Volumes Dashboard and use the Parcel/Plot Reports as it is more consistent although a bit more to manage due to parcels/plots being created
Message 72 of 72
autoMick
Here's a real simple one.
Try and change the order of the various volumes.
Cheers
Mick
Rail Community
