Civil 3D Forum
Civil 3D 2014 problem in export option
10 REPLIES 10
Message 1 of 11
dilsmails1
1170 Views, 10 Replies
Hai
My civil 3D exporting option does not showing the option of export to dwg. any one can help (image attached)
Dileep
10 REPLIES 10
Message 2 of 11
antoniovinci
in reply to: dilsmails1
"Export" means something else than .DWG...
Use "Save as" instead, sir.
Message 3 of 11
dilsmails1
in reply to: antoniovinci
what you mean by using save as ? i want civil 3d objects as dwg file
Dileep
Message 4 of 11
Jeff_M
Looks like perhaps a Repair install is in order. Although I would try a reboot of the computer, first.
This is what it should look like:
Message 5 of 11
wfberry
Perhaps the dropdown menu:  File -> Export -> Export to AutoCad -> (Pick you poison!).
Bill
 BTW, I think most of us have determined that the SAVEAS is not a good option for sending to an older version.
Message 6 of 11
dgorsman
What, specifically, are your intentions?  Converting Civil3D objects to vanilla AutoCAD objects?  Trying to save down to an earlier version of Civil3D?
Message 7 of 11
dilsmails1
in reply to: wfberry
Thanks sir,
but how can i get back my export option from let upper corner "A"
if it is possible to export a specific part from Civil 3D, same like "w block" in autocad?
Dileep
Message 8 of 11
wfberry
As Jeff said, do a repair.  Google "Repair of Autocad Installation" for instructions.  Should take about 15 minutes.
Bill
Message 9 of 11
Jay_B
2013 has this same issue on my system. I hardly use 2013 but when I need to Export to dwg from 2013 I've just been using the command EXPORTTOAUTOCADxxxx where xxxx is the dwg version to be exported to.
The command still functions normally but it is missing the icon on the Application Menu.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 10 of 11
isaac
in reply to: Jay_B
I just opened my Civil 3d 2014 program and see the same problem--the option to export to DWG has suddenly disappeared.  I tried a repair but it didn't fix the problem.
Did you find a fix for this issue?
Thanks.
Message 11 of 11
Jay_B
in reply to: isaac
No, I never did but it's working in 2014 SP2 here.
Do you have SP2 installed?
C3D 2018.1
C3D 2016 SP4
Rail Community
