Civil 3D Forum
Change Refrence Surface for Surface Elevation Label
1 REPLY 1
687 Views, 1 Reply
Is there any way to change the referenced surface on a Surface Elevation Label.
I can see the surface in the properties but cannot change it.
C3D 2011
1 REPLY 1
Jeff_M
No. But, if you have a huge number of labels you need to change, one way to do this is to remove all of the data used to create the surface the labels are on, then paste in the correct surface. Of course, this won't work if you still need that surface.
Rail Community
