Hi everyone, I need to change the color of autosnap markers for easy localization. I tried on preferences and nothing. I don't refer to ordinary autosnap markers. I attach аn image to show that I speak.
In the last image, the autosnap markers on dark green is that I need to change color.
Thanks in advance.
Try the Options dialogue (type "options", without quotes, on the command line) - Display tab - Colors... button - 2d model space - 2d Autosnap marker.
You can then set the colour on the right.
Note there is also a setting for 3d Autosnap marker in 2d model space, plus 2d Autosnap marker and 3d Autosnap marker settings for Sheet / Layout, 3D parallel projection, 3D perspective projection and Block editor.
A suggestion for the future, try searching the forums or google, "Autocad change autosnap color" gave me good results in google.
@andrewpuller3811 wrote:Try the Options dialogue (type "options", without quotes, on the command line) - Display tab - Colors... button - 2d model space - 2d Autosnap marker.
Thanks for your answer, but this meant when I said that are not ordinary autosnap markers, previously I did what you describe and I couldn't found how to change the color of the specific autosnap that I refer (dark green in previous post).
This options don't change color of autosnap markers (dark green) showed on the below image.
Regards.
I hope this clears it up:
@Anonymous wrote:I hope this clears it up:
Negative, I read the information on the link and test it, but nothing. These aren't glyphs.
It is a Civil 3D glyph. It will not be located in the AutoCAD display options and you cannot change it's color OOTB. I do not know if can be programmed to be a different color.
John Mayo
