Civil 3D Forum
Autocad Civil 3d 2013 & Windows 8
89 REPLIES 89
Message 1 of 90
16864 Views, 89 Replies
I would like to post the probleme autocad civil 3d and windows, i try to install it but during the installation wizard "framework 4" the process stopped and the installation wizard crash
can anyone post a solution for this problem
89 REPLIES 89
Message 41 of 90
After I installed Service Pack 1 my crashing issues went away.
I also installed Start8 to bring a start menu back.
I really prefer 8 to 7 now.
Message 42 of 90
Mark_Castle
I'm running C3D 2013 SP1 on Win 8 with no major issues (so far). My computer is a 5+ year-old Core 2 Duo 6400 with 2GB of RAM, and Windows 8 (32 bit) and Civil 3D both run great. I upgraded from XP, so going to Win 7 is not really an option. I've been running Win 8 since September, and upgraded to the final version the day it was released. Windows 8 boots up and runs significantly faster than XP ever did on this machine. No way would I go back to XP. BTW, I second the recommendation for Start 8. Best five bucks I've spent in a long time. Smiley Happy
Mark Castle
Win 10 64-Bit, Thinkpad P50
16 GB RAM; Core i7-6820HQ; Quadro M1000M
Message 43 of 90
Widows 8 x64 + Civil 3D 2012 = no work.
As long as I am using it as AutoCAD, it works fine.
As soon as I start thinking about creating an alignment, crash. Haven't tried anything else.
Then I discovered this topic, so at least I am not thinking about smashing my compiter anymoreSmiley LOL
Btw, my system is:
AMD A10-4600M with Radeon HD Graphics @ 2.30 GHz
8 GB of RAM
x64 Windows 8
Very dissapointed.
I saw one guy mentioning C 3D 2013 working good on Win 8.
Anybody else with positive experience on that?
Message 44 of 90
DarrenP
autodesk never said civil 3d was compatible with windows 8
DarrenP
Message 45 of 90
michael.robertson
As this thread has pretty much pointed out:
C3D 2012 & Win8 = not stable & no support
C3D 2013 w/o SP1 & Win8 = iffy & no support (some seem to not be having a problem)
C3D 2013 w/ SP1 & Win8 = works & no support
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 46 of 90
I've found that the most issues I have with windows 8 and C3D 2013 is working with profiles & pipe networks.
Luckily if I'm going to be worikng on profiles I reboot to a different HD with win 7 loaded.
Message 47 of 90
I've got the same pbromlems. Autodesk Civil 3D 2013 (on Windows 😎 is working normally like Autocad. But doesn't work at all with Alignmen, Surfaces etc...
And I think there is only one solution for this problem - uninstalling  Windows 8.
Sad but...
Message 48 of 90
neilyj666
This topic has been discussed ad nauseum - but to reiterate: at this time no version of Civil 3D IS SUPPORTED UNDER WINDOWS 8
Can we please draw a line under this topic now......Smiley Frustrated
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 49 of 90
I got it, Windows 8 isn't supported nowadays, but my question is... does anybody know when it's going to be supported? I need this program to an University's subject... so I need it quickly.
But I can't understand why it works in some computers and doesn't works in others. What does it depends?
Message 50 of 90
I have no problems on Windows 8 with the majority of what I do.
Profiles, Pipe Networks, Sections are where my problems occur.
I just reboot to a secondary HD with win 7 installed any time I
have to do the above.
HTH
Robert
Edit: Profiles work ok. Just did some last night
Message 51 of 90
My civil3d has been crashing with win8 after 45secs-1:00min from start-up with a drawing of a file size about 880kb. However, I have found a strange way of fixing it and was very coincidental. All I did was open the properties of a point in my drawing. I am positive this stops my civil3d from crashing but here is a list of other things I have done...
PROGRAM COMPATIBILITY SET TO WINDOWS 7 IN PROPERTIES WHEN RIGHT CLICKING ON THE ICON
THEN
SET USER ACCOUNTS ACCESS OFF(BAR ALL THE WAY DOWN)
DO NOT CLOSE WELCOME SCREEN (WAIT FOR THE WELCOME SCREEN TO BE SETTLED ABOUT A FEW MINS???)
KEPT PROPERTIES IN CIVIL3D OPENED AT ALL TIMES
ALSO MADE CREATE POINTS BAR PINNED
Message 52 of 90
in reply to: Mark_Castle
Forgive my ignorance, but which SP1 are you saying about? AutoCAD Civil 3D 2013 Service Pack 1?  I've read what was written about this SP1 it but there's nothing about it supports Win 8.
Message 53 of 90
I did everything you've recommended and I installed AutoCAD Civil 3D 2013 Service Pack 1.
I don't know which one helped may be both. But I've tryed few simple things and it's working!
I want to thank everyone for the help Smiley Happy
Message 54 of 90
hello i see ur problem in the program civil 3d
did u  find any solution for this problem please reply me quickly coz i have the same problem and iam soo disapointed :S
Message 55 of 90
can u tell me that steps by details again ???on win 8
Message 56 of 90
AllenJessup
Search the group. sr.PNG there have been may posts on this subject including today. Why are you disappointed? Because a program that isn't supported under Windows 8 doesn't run well on it. That should have pretty much been expected.
Don't by hardware or an OS and hope your programs will run on it. Buy what you know will run the programs that are important to you.
Allen Jessup
Civil 3D 2012 SP 2.1
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
Message 57 of 90
in reply to: AllenJessup
i do this steps but what is the solution for make my program run and faster ??
Message 58 of 90
Buy a FAST computer. Install a SSD as your main drive.
I just built a cad station for $600 with a i5 3570, 8 GB Ram, 120gb SSD and ON-BOARD intell HD 4000 graphics.
Runs 2 monitors great. All I her from the 2 tech's that use it is that it is smoother than any of the other pc's.
Bo
Message 59 of 90
my lab specs is
8 GB of RAM
x64 Windows 8
nd it's still slowly nd bad :S
Message 60 of 90
michael.robertson
Could we stop with all the Windows 8/Civil 3D posts?
It may or may not work and is not supported.
If people want to talk computers specs start a new thread please.
Mike Robertson
Rail Community
