Will an ANZ Country kit be provided for C3D 2015? If so, when?
Solved by Jeff_M. Go to Solution.
I just installed the entire Infrastructure suite of 2015 and did not see any prompt for country kits. Did I miss a step?
At the screen showing which programs to install there was a down arrow below the Civil C3 2015 option, this expands to where you can select the different options, including the Country Kits. You can still install it by going to Control Panel, Uninstall a program, select C3D2015. It will come up with a screen to select Add/Remove Features, Repair/Reinstall, or Uninstall. Choose the Add/Remove Features option.
Thanks for your help. Unfortunately when I select the add/remove features button, nothing happens. Worse still I cannot close/exit the window except by ending task in task manager.
Looks like the Suite version takes a while to determine what can be updated. Have patience...it took nearly 5 minutes from the time I chose Add or Remove Content for the list to display. During this time I was unable to get any other button to function.
I just installed the UKIE country kit and now my US Imperial and US Metric kits have gone away. Where are the US Imperial and Metric .xml files located so that I can get those shortcuts back on my desktop?
