Civil 3D Forum
Adding alignment profile to existing p-view
4 REPLIES 4
randcdavidson
12222 Views, 4 Replies
I have one surface "EG" and two alignments, I'll call 1 and 2. The profile view already has the alignment 1 surface projected on it. I go to profile>Create Surface Profile and select alignment 2, Surface EG, go to ADD it but the profile list is empty. Shouldn't it already be populated with alignment 1 and all I'm doing is adding 2 to it? Both alignments are in the same site.
4 REPLIES 4
sboon
in reply to: randcdavidson
Each profile view can only display the data from one alignment, unless you use the Superimpose command.
Steve
Expert Elite Alumnus
You can only have one profile view per alignment. So, in this case, you will have two profile views: one for Alignment 1, and a second for Alignment 2. Both will reflect your EG surface as a profile along the length of each alignment.
If you wish the profile created in profile view Alignment 1 to appear in the profile view of Alignment 2 (or vice-versa), you can use the Superimpose Profile command. The results will depend on the relationship between the two alignments. If they are close together, for example, the resultant may be something useful. If they are far apart or otherwise disconnected, the pair in on proifle view might have no useful meaning.
It's what sboon said, with some smoke and mirrors added.
sboon
You can have as many profile views as you want, but each one can ONLY reference one alignment.
FTFY Smiley LOL
Steve
in reply to: sboon
Yeah, that's what I meant!!
Rail Community
