Ok, I'm stumped. I am using the Dynamic North arrow that is linked to the viewport. It doesn't matter if I use an OOTB block or a custom one they all have a rotation of 355.4016.
The viewport is type "Plan", Dview twist is set to "0", USC is World.
If I change the rotation on the block it rotates the viewport (as expected).
The default block is not rotated. Any suggestions?
BTW, It works fin in the default NCS, so it's something in my template.
Solved by C3D_TomR. Go to Solution.
This does not remove the coordinate systems from your drawing(dwt). It just removes the association of the True north being repersented on the north arrow and navcube.
The already placed NA's can be reset after you remove the GEO if needed. The Navcube can be turned of in the template file and if you don't use the auto north arrows, no one even knows it is rotated slightly. You cna even set them to remove the north rotation and be straight up, but when you do it rotates the viewport.
I have even cheated and placed the associated NA on a no plot layer and had a plotted NA that is not associated with the viewport. SO one noplot controls the rotation, one is plotted. ANother reason for this is the plotted NA is a custom one, and when I tried for a few minutes to make it a smart one it gave me issues. I'm always pressed for time, it is on th elist to revisit in the future.
I was wrong about resetting the NA it still rotates the viewprt. I forgot, I bring it in again after the GEO removal.
I had similar issues trying to use our standard north arrow. It has a north arrow assigned to a rotation parameter. The north arrow rotates inside of a box with text. I like your idea of having the dynamic one on a no-plot layer for a visual notification of a major change in the viewport.
See what happens if you follow this scenario.:
At this point what I'm seeing is that everytime I check the Units and Zone tab and choose OK, the geographic location gets reset. So let's set it then continue without OK.
Can see where the coord system holds and where it doesn't?
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
@Anonymous wrote:
Geographiclocation only request a file or a map in Civil 3D.
Working on setting this up in 2015 and had similar problem as this poster, found a solution to this part at least, still testign the rest.
In 2015 GEO does not offer to let you remove the geo location. instead
Of course this still doesn't solve the problem where if you use a dynamic north arrow you can't have a datum assigned to the drawing without jumping through hoops.
The answer lies in the transformation settings tab of the drawing setting dialog. if you tick the box to apply transformations you can then type 0 in the "to North" angle and then re attach your north arrow to your viewport and the rotation issue will be fixed. Not sure what happens when you change coordinate zones though!
Cheers
Yes, I know this is an old thread.
Chewed on this for quite a while, and thought about what "North" represents:
Then it occured to me that what everyone thinks is "True" North would be better called AutoCAD North, or Top-of-Page. ANY map projection has distortion, both distance and direction. The direction distortion is called Convergence, or Mapping Angle:
So when you force C3D to display the North Arrow "Straight Up", you won't have Grid North, or even "True" North. You'll have AutoCAD North, which completely disregards your Map Projection.
I made up a Screencast using Bruce's Northarrow drawing. In it I zoomed WAAAAAAAY out and moved my cursor East and West of the GeoMarker, aka @mcloughlin 's "Crop Circle".
Dave Stoll
Las Vegas, Nevada
Civil 3D 2016. Still seems to be a problem.
I just want the thing to point upwards.
I don't want to mess with grid and coordinate systems just to get it working.
I've given up. The effort isn't worth it. Back to model-space north arrows.
TBox,
"I just want the thing to point upwards."
Then don't assign a Coordinate System. Use "No Projection, No Datum" and you will never again have to deal with it. Of course, you won't be able to use Bing Live Maps or bring in GIS data.
Dave
Dave Stoll
Las Vegas, Nevada
I don't like this.
There should be a way to have an arrow pointed "up" even with a coordinate system. You still have a world UCS, dontcha? There's no way to leave the coordinate system on and get a world UCS north arrow linked to the viewport? The viewport is showing a world UCS, rotated or not, isn't it? Bah!
How do the arrows in plan production work right if this doesn't? I'm sure I've had drawings with coordinate systems that I've spit plan & profile out from that the north arrows come out right...Although my sheet template for plan production isn't geolocated. Maybe that's it.
I've decided that I'm just going to continue to use this LISP for rotating north arrows. I didn't write it. I don't know who did, but goodonya. I post it here in case someone is at the same point that I am and would settle for automatically--but NOT dynamically--rotating north arrows in paperspace. Putting north arrows in modelspace is not a solution I'm willing to live with.
(defun c:rn()
(setq tw(entget(car(entsel" Select a Viewport:"))))
(setq new (cdr (assoc 0 tw)))
(cond
((= new "VIEWPORT")(setq rt(cdr(assoc 51 tw))))
((= new "LWPOLYLINE")(setq temp (entget(cdr (assoc 330 tw))))(setq rt(cdr(assoc 51 temp))))
(setq en(car(entsel" Select North Arrow: ")))
(setq elist(entget en))
(setq elist(subst (cons 50 rt)(assoc 50 elist) elist))
(entmod elist)
(princ)
J,
"There should be a way to have an arrow pointed "up" even with a coordinate system."
Why, of course there's a way. Make yourself an arrow block and point it any way you want. You can even point it in the "Z" direction, straight at you!
What you seem to want is not "North", but "Top of Page". Why would that be useful? Anyone can immediately see which side is up, without an arrow.
Dave
Dave Stoll
Las Vegas, Nevada
I didn't mean top of page. I meant with the Y-axis in the world UCS, regardles of assigned geo-coordinate system. I've got an assigned coordinate system and my Y-axis doesn't get all bent if I pan way east or west. I want the same behavior out of a north arrow.
Your video, (which was, as always, both wonderfully informative and visually pleasing), where you moved the crosshairs within the viewport and the dynamic north arrow changed, allowed me to understand the behavior of dynamic north arrows vis-a-vis geo-coordinate systems. I doubt if I'd had really understood it without that exact video.
But what I want is a paperspace dynamic north arrow that points up like my Y-axis within the viewport points up. And changes with that. Like the plan production arrows do. An arrow that is smart enough to change with the viewport but dumb enough not to know where real north is.
That LISP I posted takes a north arrow and rotates it to a viewport. If I rotate it to a viewport showing a geo-coordinate system, it still points up if my UCS is oriented "up". The dynamic ones come in slightly skewed.
I think I made a screencast. (I pasted the URL.) My first one, so not sure.
J,
"An arrow that is smart enough to change with the viewport but dumb enough not to know where real north is."
I like that! Well said!
Dave
Dave Stoll
Las Vegas, Nevada
Tom Richardson
Twitter | LinkedIn
I know this thread isn't exactly new but I was aiding one of my users today who was experiencing this behavior. The slight rotation of the linked north arrow seemed to be the result of a coordinate system being designated for the drawing (in our case NJ83F) and the area show within the viewport not being within that coordinate system (coords were something close to 0,0) We cleared the coordinate system setting and all was well as the items drawn were not within that coordinate system to begin with.
I was curious about the behavior so I returned to my machine for further testing. I opened out template drawing that already has a viewport with a linked north arrow, set a coordinate system and then centered the viewport around 0,0. The linked north arrow displayed a rotation value of 359. I then recentered the viewport to a location that I knew was well within the designated coordinate system and the north arrow rotation value was now 0. I panned around, staying within that coord system and the value stayed at 0. Then I panned about 1200 miles to the east, waaay outside that system and the arrow showed 355. So, it seems that your viewport needs to be viewing an area that is within the set coordinate system for the linked north arrow to have a rotation value of 0.
Well, I dunno. I thought it might be just because I'm so much closer to the pole here, but I changed my coordinate system to New Jersey and I get the same result. The closer I get to the geomarker, the more north the arrow is. When I move around within the coordinates for either AK83F or NJ83F, the arrow gets more and more skewed the father east/west I go. If I'm outside the coordinates, then, it is more skewed, but it started being skewed well within the coordinates.
I did notice a "Reset to north-up" option on the settings flyout attached to the dynamic north arrow. (C3D 2017.) I hadn't noticed that before. Or I forgot about it. Perhaps you hit this and then were seeing no skew in your north arrow within your coordinates?
Anyway, if you are seeing the paperspace arrow pointing straight up, then I believe you're also seeing your world coordinate system skewed. This is the problem I'm referring to, (being that I'm working with pseudo-state plane coordinates, but want to enjoy the benefits of georeferencing). I want both the UCS and the north arrow to be World. The arrow is too smart for it's own good.
...Unless I'm missing something. If you can pan east/west in your coordinate zone and have both the paperspace arrow and the UCS in modelspace both point up, please let me know. And, if possible, let me know how you did it.
Thanks.
