Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Examples for StationOffset in C#
4 REPLIES 4
brianchapmandesign
1368 Views, 4 Replies
Need an example of how to use StationOffset() in civil3d.  I used point3d to get a var x and var y.... need to know how to select my alignment and report the station/offset for that coordinate. Any help / examples would be most appreciated.
Thanks!
"Very funny, Scotty. Now beam down my clothes.
4 REPLIES 4
Diggin through Sinpac Free Source...maybe I'll figure out
Jeff_M
in reply to: brianchapmandesign
A word of caution. While the SincpacC3D source code may be of some benefit, it was originally written based on the C3D2007 API's. A lot has changed since then, specifically the .NET API's were born, so those examples do not have anything that deals with these newer API's.
Jeff_M
And some sample code using the .NET API:
        [CommandMethod("AlignmentTest")]
        public void alignmenttest()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            ObjectId alignId = SelectAlignment(doc.Editor);
            if (alignId == ObjectId.Null)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Alignment align = (Alignment)alignId.GetObject(OpenMode.ForRead);
                double station = Double.NaN;
                double offset = Double.NaN;
                PromptPointOptions ptOpts = new PromptPointOptions("\nPick point for Station/Offset:");
                ptOpts.AllowNone = true;
                ptOpts.AllowArbitraryInput = false;
                PromptPointResult ptRes =  doc.Editor.GetPoint(ptOpts);
                while (ptRes.Status == PromptStatus.OK)
                    try
                        align.StationOffset(ptRes.Value.X, ptRes.Value.Y, ref station, ref offset);
                        doc.Editor.WriteMessage("\nThe station and offset at the picked point is: {0}, {1}", align.GetStationStringWithEquations(station), offset.ToString("F2"));
                    catch (Autodesk.Civil.CivilException ex)
                        string msg = ex.Message;
        private ObjectId SelectAlignment(Editor ed)
            ObjectId result = ObjectId.Null;
            PromptEntityOptions entOpts = new PromptEntityOptions("\nSelect alignment: ");
            entOpts.SetRejectMessage("...not an Alignment, try again!:");
            entOpts.AddAllowedClass(typeof(Alignment), true);
            PromptEntityResult entRes = ed.GetEntity(entOpts);
            if (entRes.Status == PromptStatus.OK)
                result = entRes.ObjectId;
            return result;
Thanks Jeff!  I was able to finally put something together real late last night... but your code shows me where I worked way too hard lol.... much appreciated!
Rail Community
