Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Bing Map Images Stopped Working
14 REPLIES 14
Message 1 of 15
jmartt
1977 Views, 14 Replies
Bing map images stopped working for me today. On two different computers. With different profiles.
I've turned my hidden message back on and picked "yes" to showing online maps, just to be sure.
The 3D coordinate sytem is correct.
Georeferenced drawings will show the geolocation tab, with the online map buttons not grayed-out, and I can switch from Map Off to Aerial to Hybrid, etc., but nothing happens. I've zoomed in and out and regened.
I can bring in georeferenced data and it lands in the right spot relative to each other and the coordinates look like something I'd expect.
If I attempt to capture an area I get "FATAL ERROR: Unhandled...."
Never happened before.
Any ideas would be appreciated. Thanks.
14 REPLIES 14
Message 2 of 15
in reply to: jmartt
We're having the same issue here on multiple stations using Map 3D and long with Civil 3D. I've tried everything you can think of from creating a new 360 profile, hardward exceleration, and various others. Rumor has it that Bing may have had a crash sometime yesterday around 2:00 PM Central Time. Also, one of my co-workers has placed two tickets to different CAD sources to see if they have heard something as well. Please share if you find out the answer. Thanks!
Message 3 of 15
opsis
Did you manage to rectify this problem please? I'm having the same problems at the minute.
Message 4 of 15
in reply to: opsis
Here is the answer we got this morning:
Latest word from Phil Borycens: "A fix is targeted for the end of this week (Nov 7th). When the fix is live, AutoCAD users should see a message indicating that a fix is available when trying to use any of the Geolocation functionality."
neilyj (No connection with Autodesk other than using the products in the real world)
Message 5 of 15
opsis
Thanks cchuls
Message 6 of 15
in reply to: opsis
Here is the link to the fix. You'll need to make sure you have all the security updates and service packs up to date prior to installing.
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoca...
Message 7 of 15
cdavis
in reply to: jmartt
OK.. I have a question on this now. I have the latest Service Pack, added the hot fix for geolocation, but I still cannot get my maps to show up. I sign in to 360, set my location, but when I go to edit the location by map, it says that maps cannot be displayed becaus I am either offline, not signed in to 360, or have chosen not to use live maps. In all 3 cases this is not true. Anyone have a solution as to where I am going wrong?
Chris M. Davis
Message 8 of 15
alg_v-k
in reply to: cdavis
I have the same thing happening.
Message 9 of 15
alex.cecato
in reply to: cdavis
+1
can anyone help us ??????
Message 10 of 15
in reply to: alex.cecato
I'm sure you've tried to sign into 360 multiple times. But sometimes even when it says you are signed in, during the AutoCAD session you're really not. Try to go to the Get Started page and see if you are signed in there. I know I had that issue on mine after the new hotfix was installed. See if that clears things up hopefully.
Message 11 of 15
alex.cecato
Yesss !
Thanks a lot !
Message 12 of 15
cdavis
I am still unable to use the service. I have done the updates and patches and even the latest 360 update. Now I have this message that appears:
I click on account settings and all I can do is change my password. Anyone else have any ideas on how to get this to work?
Chris
Message 13 of 15
dce
in reply to: jmartt
Anyone know if Bing Maps is down again?
I can't get mine to work this morning.
Message 14 of 15
in reply to: dce
Everything has been working so far lately. I know myself and others in the office have been asked quite frequently to sign into 360 when Map/Civil starts up. I'm sure you have varified that you were signed in already. If you have modified CAD recently you may want to check if you have that hotfix installed again.
Message 15 of 15
jporter
I hate to rais the dead here, but I have a user running Civil 3D 2015 who already installed the Bing hotfix (before the cutoff date of October 29, 2014) and has been connecting to Bing and capturing images fine all this time.  Just last week he used it.  However, today he connected to the Bing map fine, but when he attempts to capture an area he continuously gets a fatal error.  We've signed out of A360, restarted the system, and verified the hotfix is there, but no luck.
Any ideas?
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Rail Community
