Is there a way to map the velocity/pressure results from an outlet, and subsequently map the result to an inlet of some other components/systems?
An example of application would be:
a centrifugal pump is simulate to obtain the simulated fluid's behaviour (velocity/pressure) at the outlet.
Next, the same results are mapped to the inlet of a rotating fluid tank that it is attached to.
Of course, both the simulation can be done in one go, but if there are 2 or 3 different configurations for the fluid tank, but all are attached with the same pump design. It would save a lot of time by just applying the mapped results from the first simulation.
