Hi, I'd like to validate the CFD results and have big problem. I simulated stright pipe: d=0.01 m (internal diameter), l= 1 m length mi = 0.052 Pa*s dynamic viscosity, V = 3 m/s - average oil speed, ro = 857 kg/m^3, p=0 bar outlet pressure Re=500 - laminar flow smooth pipe. I measured the pressure in the half of the length to avoid forming influence and got 0.61 bar static pressure but it should be 0.25 bar. I tried different mesh, different iteration numbers, but always pressure drop was too high and similar. It is isothermic flow. What is wrong? Please look at the model attached.
Wojciech
P.S. I've chosen VG 32 hydraulic oil with 40 deg.C and should get ca 32 cSt kinematic viscosity for this temperature but it was 61 cSt. Something is wrong with the library viscosity characteristics This is no big problem but still.
Today I use 1e6 elements and it looks better. The issue with library oil viscosity characteristics is still valid
Wojciech
