Can Autodesk Simulation CFD 2014 simulation the flow of the oil-water separator?
Solved by OmkarJ. Go to Solution.
If oil and water enter as a mixture, you would need Eulerian framework to simulate the multiphase physics, which SimCFD doesn't have. If you just need to simulate the interface between the oil and water, you can use free surface model, but this case doesn't sound like that, as the phases appear mixed. If the dispersed phase (I presume oil) has very small volume fraction (less than 5-10%) you may want to use massed particle that use Langrangian framework.
OJ
we are supplier for oil water filtration and sepration technlogy
Thanks and Regards,
Irfan Farooq
Director |AL ATTA CONSULTATIONS & ADMIN STUDIES EST.
Marine & Industrial Division
Tel: +971 4 2953325|Fax : 042 953326| Office no 340, Galadari Mazda Showroom Dubai Intl Airport
Opposite Abu Hail Metro Station DUBAI-UNITED ARAB EMIRATES
Direct: +971 50 6990539 | info@aacmarine.com
Website: www.aacmarine.com www.aiconsultancy.com
