CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Material database file not found
7 REPLIES 7
Message 1 of 8
tomob57
914 Views, 7 Replies
When I open Simulation CFD for the first time, I get a message telling me that a material database file was not found.
I have verified that matprop.cfdmdb exists, it is exactly where it should be.
I then tried to delete the 'cfdesign_db_dictionary.xml' file like it suggests, but that file isn't there so I couldn't do that.
Finally I tried to run 'CFdConfig'; but that file isn't there either.
Does anyone have any ideas?
Thanks.
7 REPLIES 7
Message 2 of 8
georgelawrance515
in reply to: tomob57
hello
slim chance as this post was over 10 years ago but how did you solve this as i am experiencing this issue now.
Message 3 of 8
Hi @georgelawrance515!
Navigate to C:\Program Files\Autodesk\CFD 20XX and run CFDconfig.exe as administrator, then proceed with configuration. That should repair the database path.
Best,
Tim
Message 4 of 8
hello, thanks for the help but i have ran the CFD config twice and im getting the same error. I've attached some images of what im getting. i have the matprop file on the program files and have tried renaming it like it says, when it says rename is it simply changing the name or do i need to change the file type. any help is much appreciated.
thanks
George cfdconfig.pngScreenshot 2024-03-20 072531.pngScreenshot 2024-03-20 073748.png
Message 5 of 8
Have you tried uninstalling CFD via Control Panel and then installing it back with installation file from manage.autodesk.com?
I've also noticed that you are using CFD2021, I highly recommend switching to CFD2024 as it has a lot of bug fixes.
Best,
Tim
Message 6 of 8
georgelawrance515
i have tried deleting and installing multiple times, i also have had 2024 version and got the same issue. i will try again using manage.autodesk.com. cheers
Message 7 of 8
ive tried 2021 again and still getting the same issue. when i try and install 2024 nothing happens after i run the install application. is this a common issue which you know about. cheers
george
Message 8 of 8
Assuming you are installing CFD with official installer from manage.autodesk.com my last idea is to try performing a clear uninstall of CFD following this article: [LINK].
Are you installing CFD in the default folder path?
Are you using external or network drive?
