Hello all,
CFdesign had the "HPC module", which was required for >4 cores (single system or cluster). The HPC module requirement seems to have been removed from Simulation CFD 2012. Can anyone tell me what the licensing requirements are now for a cluster? Do you just need a single solver license for the head node, regardless of the number of cores/nodes the cluster has in total?
Many thanks,
James.
Solved by derrek.cooper. Go to Solution.
Hi James,
You are correct. The license requirements for the HPC module are now included with the solver licenses and a seperate license is no longer needed. CFD 2012 will support 2^n cores on the machine that you are using out of the box.
-Royce
Thanks Royce. Sorry I'm being a bit dumb - when you say it supports 2 to the n cores "on the machine you are using" could you clarify what you mean (is n the number of solver licences?) For example, let's assume I have a 4 node cluster, each node has 4 cores - so 16 cores in total. Will a single solver license on the head node suffice, or are you saying we need 4 licences on the head node (2^4) to cover 16 cores?
James.
Hi Royce - any chance of an update on this please? What is "n" when you say that CFD 2012 will support 2^n cores?
James.
Hi James.. we will leverage chip sets that are 2^n # of cores (4, 8, 16).. So chips with 6 cores, we will use 4 cores..
OK I see, many thanks for explaining that Derrek.
Do you have any info on whether a cluster requires more than one license, or will a single solver license (installed on the head node) cover all available cores (ie: including those on the compute nodes too)?
James.
Just replying to my own question ... no extra licenses are required for a cluster vs a single workstation. Good news!
