Has the licensing model changed at all for the release of 2015? I ask becuase we're having licensing messages pop up where there were none before.
Lots of the messages seem to focus on the ProE interconnect if that might be the cause?
Ta in advance for your assistance.
The licensing framework was updated but the general structure did not change. Can you be more specific about the messages you are recieving?
This might be better handled through our support team.
Specifically, the message reads:
"The license is no longer accessible. You do not have a
license for Simulation CFD Connection for Pro/Engineer
Your data will now be saved and Autodesk Simulation CFD will stop."
I was posting on here to see if anyone else had the same issue or if it was just us.
Hi Rob,
Can I suggest we move this question over to the installation and licencing section? They should be able to advise. Or you could log a case and we can send it directly to the team.
Kind regards,
Jon
No problem Rob,
I was going to move this one over but now it is marked as solved I think perhaps a copy and paste on your end might be better 🙂
