Hi, I used the "assembly" option to upload my MEP file with its associated arch linked in model. That worked fine, but now I'd like to upload a new version of that file. I tried to just upload the elec file on its own, but that meant the arch/linked file didn't show anymore in the new version.
How do you go about doing this? I'm using the BIM 360 team online.
Thanks.
Solved by mkhodr. Go to Solution.
A little more digging and it seems this isn't possible? https://forums.autodesk.com/t5/bim-360-team-forum/new-version-assembly/td-p/7108914
EDIT: nevermind, as one of the posts in that thread mentions, if you re-upload the new version of the file (with the same name) as "assembly" it will automatically become a new version. Problem solved.
