Show only
Search instead for
Is there a way to keep your template the same as the paper size (ie 8.5x11) while altering your scale? I change the scale and my border template gets huge or small. I've tried locking it into the title block layer, doesn't change anything.
But a quick work around would be to select everything in the template and use the "scale" tool, choosing a factor that will undo the change in your object
