Stephen,
I can see and understand some of what you are saying. I can't imagine that 2.1
could actually draw as well as V7 for me because obviously it would lack some of
the features I like in a more modern software. The Auto snap for one.
Another issue you mention was drawings that might be "representative" of
something. Interestingly, I use Sketch to actually produce things on that 1 to 1
level. When I draw something and use those lines to create toolpaths for
machining, it HAS to be scaled correctly or the part is wrong.
My understanding of V5 is that it is different than the V6 and V7 versions and
takes a bit to get up to speed with it. My very first version was 6. I bought it
just before I even knew 7 was close to coming out. After installing 6, and
deciding I did not like the mandatory "manual snap point entry", I pretty much
gave up on using it. Then when I read that 7 included autosnap I bought it.
After learning to live with a few minor issues, I would be the first to say that
Version 7 is a great way to draw. With One or two repairs in the drawing
methods, and a few tweaks in the installation, compatability and stability with
other hardware, it would be an excellent program. But, you order V8......
So, In my opinion, Stick out the V8. Give it your best shot. USE the auto snap
functions even though it seems like they were a big turn off to V6 users(well,
that, and backwards compatability- DUH, A-desk !). It may be that after a few
months of people reporting the wierd problems 8 might have, one can find the
workarounds necessary and live with it until V9 introduces all new problems.
OR, send the V8 back when you get it. V7 works fine on Win2k or at least fine
enough for me. (watch file size growth) Let V8 mature. I do not see why V7 would
not work on XP. No sense you being new to the techniques used with the newer
version than you are used to AND doing "Bug Patrol". Learning a new program is
hard enough when it works !
And too, you have the double whammy of using a new operating system. Some of
those reports do not look to good without applying bug patches as well. Lets
see, Remember when Autosketch was/is toughted as being MS office like ??......
XP security holes....... H'mmmmm they were right !
CL
Stephen Tall wrote:
> I tend to think that people only like 2.1 because it's what they are used to
> and don't want to spend time having to learn what is essentially a different
> package. I never really manged to get to grips with 2.1 and so when along
> came AS5 it fitted like a tailored glove (allbeit with a couple of pins left
> in it though!). With 2.1 I struggled to produce accurate drawings,
> generally they were more "representetive" than correctly scaled etc. I am
> at the point where any drawings that I have in the old 2.1 format get
> redrawn if they need modifying because it takes so long to correct them
> (even the ones that did get draw corectly). But there, I'm only in favour
> of AS7 because I get on with it.
> "Chris L" wrote in message
> news:3C3BCC5B.7D8052A@lakefield.net...
> > Boy, I sure wish I could see a copy of 2.1. Don't send it to me though...
> I'd
> > hate to see one of you guys sit in jail over it because of some licensing
> issue.
> > I hear so much about how nice 2.1 was, when I settled in with V7 and enjoy
> it
> > pretty much. Well, other than getting used to the little bugaboos it has.
> I just
> > did not like V6 because of the manual entry snap commands. I'm human...
> not an
> > octopus !
> > Right now I guess I'm "locked into it" (v7) unless I switch to something
> else
> > completely. Jury is still out on that.
> > I bet by using LFN with 2.1, (lfn is a freeware, long file name support
> tool for
> > older 16 bit programs) it might be pretty useful however, I have a hunch I
> need
> > to grow a few extra arms for entering snap commands.
> > CL
> > John Howard wrote:
> > > Many years ago I was introduced to AutoSketch 2.1, and even though I was
> a
> > > computer novice, I was up & running in short order. Since then I have
> > > upgraded to both VS.5 & VS.7 as well as AutoCAD Lt.VS.3. Always
> frustrated
> > > with the cumbersome tools, I would reverted to that which I knew. I
> have
> > > now after being convinced that Windows XP would run my VS.2.1, have
> found
> > > that I can't print. I have ordered a Autosketch VS.8 with the
> anticipated
> > > fear that it will resemble VS.7. I have also ordered an updated
> AutoCAD
> > > Lt. demo. I have no experience with Quick Cad. Is there a consensus as
> to
> > > which program is the least cumbersome to learn and what draw backs may
> there
> > > be? Are there other products that I should concider? My other recourse
> is
> > > to do a duel boot with Windows 98 and XP, any thoughts & or concerns?
> Would
> > > someone at AutoDesk R&D please persuade the almighty powers that be to
> > > resurrect AutoSketch 2.1.
