IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
VR material editor
4 REPLIES 4
195 Views, 4 Replies
VR material editor
When i change a difuse color in Material editor,why won't the
sample box show the new color  ?
Can someone walk me through the process ?
Thanks in
advance.
4 REPLIES 4
Im not sure what you are doing.  But this
simple process works here.  Clicking on the diffuse color swatch and pic a
new color, and the color is reflected in the sample slots.  Are you using a
material with a bitmap which is overriding a color?
Steven D. Papke
KBJ Architects, Inc.
Visit the
Vizdepot!
http://www.vizdepot.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Thanks in
advance.
I just pick a sample & rename it
& pick a color,but the preview does'nt change to the pickrd
color
a new color, and the color is reflected in the sample slots.  Are you
using a material with a bitmap which is overriding a color?
Steven D. Papke
Visit the
Vizdepot!
href="http://www.vizdepot.com">http://www.vizdepot.com
the sample box show the new color  ?
Thanks in
advance.
Why not post a screen shot so we can see the
ME.
Steven D. Papke
Visit the
Vizdepot!
color
pic a new color, and the color is reflected in the sample slots.  Are
you using a material with a bitmap which is overriding a color?
Steven D. Papke
Visit the
Vizdepot!
Thanks in
advance.
Hi there,
You didn't give us enough information, so I am assuming this is the case:
you have a diffuse map applied to the material.
If that's the case, the sample box won't change because you already
have a map applied to it. You need to change the Diffuse Map amount or remove
the map to see changes in color.
If you want to change the color of your map, you need to do that in a paint
program.
Alexander
Thanks in
advance.
