IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Correct Upside down dimensions
7 REPLIES 7
Message 1 of 8
1145 Views, 7 Replies
I have a viewport I rotated 90 degrees. In the model I have a string of vertical dimensions on the right side of the model. In the viewport the dimensions are horizontal and upside down. How can I get the dimension text to show up right side up?
7 REPLIES 7
Message 2 of 8
Use the correct UCS when you are placing the dimensions?
wrote in message news:5540428@discussion.autodesk.com...
Message 3 of 8
dimedit, rotate
Message 4 of 8
This works great:
;;by David Kozina
(defun C:FLIPTEXT (/ ss i ent ele)
(setq ss (ssget '((0 . "DIMENSION")))
i (1- (sslength ss)))
(while (not (minusp i))
(setq ent (ssname ss i)
ele (entget ent))
(entmod
(subst (cons 51 (- (abs (cdr (assoc 51 ele))) PI))
(assoc 51 ele)
ele))
(entupd ent)
(setq i (1- i))))
(defun c:DTF () (c:FLIPTEXT)(princ))
"kstill" wrote in message
news:5540533@discussion.autodesk.com...
dimedit, rotate
Message 5 of 8
Thanks for all your suggestions!
Message 6 of 8
Because it is arch-desktop group, may meaned about
AEC dimension. Independently of current UCS, AEC dimensions are
always drawn by WCS.. I had this problem too, may I rotate all model ?
"kstill" wrote in message news:5540533@discussion.autodesk.com...
dimedit, rotate
Message 7 of 8
I'm not sure what you mean. I used generic dimensions, not AEC dimensions. The LISP program worked great for me.
Message 8 of 8
Ok, I see. In generic dimensions that problem I described not exists.
If You are using arch-desktop, also try AEC dimensions - very useful thing.
wrote in message news:5574748@discussion.autodesk.com...
