Thanks for the congrats, Danny! Hope the brain dump is useful to you.
Answer: Yes, MVBlocks must be tag anchored to an object in order to have
data show up in attributes. Your suggestion is a very good idea and would be
trivial to implement, but I believe that implementation would break the
current rules for an extension. I recommend posting this on the wishes
group.
Thanks!
Scott Arvin
"Danny P." wrote in message
news:93BDB8E6D0AB6A4E62129C0475EF6903@in.WebX.maYIadrTaRb...
> Scott,
> A most excellent brain-dump, and I congratulate you on your efforts. I
know
> it's crazy to get all geeked up on schedules, but this is great!
> Question: In the document, you mentioned Paul's suggestion of naming a
room
> based on an adjacent room using location properties. So that got me
> thinking that I could create a tag (an MVBlock) with a location property
> that reads the room name just by putting the location grip on top of it.
I
> managed to get everything working except that the tag doesn't display the
> data. When I click on the tag, I can see in the Properties palette that
the
> tag has the data on the Extended Data tab, and the attributes have the
> correct name. Do MVBlock tags still have to be anchored to an object in
> order to have the data show up in the attributes? This is obvious in
> previous versions, but now that properties can come from other objects
> without anchoring, it might be a great extension candidate.
> Thanks!
> -Danny Polkinhorn
> "Scott Arvin" wrote in message
> news:82023E9254A8220EF49987637FC05D28@in.WebX.maYIadrTaRb...
> > I just posted a brain dump on property data enhancements in ADT 2004 on
> the
> > autodesk.aec.arch-desktop.customer-gallery newsgroup.
> > Enjoy!
> > Scott Arvin
> > Autodesk
