how about the exterior walls?
if they are drawn as 30' high, how do you only show the windows for the
second floor? i guess one *could* make the exterior walls in each floor plan
drawing, but then you must refedit the exterior walls.... i think thats a
major PIA. the exterior of the building should be edited all at once. see
the threads of 28.mmar.01 "re:repost 3d model" and 29.mar.01 "xclipped xref
does not show in plan view". i also outlined a method for much the same
thing as you.... i think it may have been in one of the threads listed above
or one even earlier....
Biull Glennie was going to see about posting a file with the correct way to
set cut planes above and below a floor slab to isolate the exterior wall to
display only in the correct "z- zone"...
i am in agreement with you on the ideas..... i just cant figure out how to
make it work.
ljp
"Mark" wrote in message
news:123E9B2E780CFDFB97A3A21BA1D4BC81@in.WebX.maYIadrTaRb...
> I hav seen various wishes in these newsgroups for the ability to edit
> multiple storey buildings in one file. Here's my solution that nearly
> achieves this and also lets people who want to edit one file per floor
also
> work on the same project.
> 1. Set up the project in the traditional ADT way with one floor per file.
> 2. Make a model file with each floor file xrefed in.
> 3. In the model file make a layout for each floor showing only the layers
> required for that floor plus local UCS to give the correct height.
> 4. Edit the various floors using refedit in the relevant floor layout.
> Layer steering for each storey using wildcards is easy using the xref
name,
> no extra level keys in the layer standard for those working in the model
> file.
> I must admit that I have not tried this on a real project (I'm happy
enough
> with the 'traditional' way), but i don't see why it shouldn't work
> Mark Ratcliff
