AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Specs for AutoCAD Plant 3D
4 REPLIES 4
guillermo.canon
1267 Views, 4 Replies
Hi
Any place where I can Download Specs for AutoCAD Plant 3D?
Gracias
4 REPLIES 4
in reply to: guillermo.canon
As far as I know there is no place where you can download P3D specs or catalogs.
Peter Hammink
Primat Project Service BV
gulnacm
The specs that are provided by Plant 3D are located at (.pspc & .pspx files)
C:\ProgramData\Autodesk\AutoCAD Plant 3D\Content\Specs
The catalogs that are provided by Plant 3D are located at (.pcat files)
C:\ProgramData\Autodesk\AutoCAD Plant 3D\Content\Catalogs
For default installs
Mike G (Autodesk)
Michael Gulnac
Technical Specialist
Organization
Mike,
What we need is to work with this Spec (please see attached file)
Coudl you please let me know the general procedure to implement it? Is possible to get this files somewhere?
Gracias
gulnacm
The content that is included with Plant 3D catalogs is mostly ASME B16.10 and DIN. The specs are all based on the included catalogs. The spec sheets that you show looks to be clamped tube fittings. We currently do not have this type of piping content with Plant 3D. This is something that we will be adding in future releases.
We currently do not offer a spec and catalog download. We inlcude them in the install
Mike G
Michael Gulnac
Organization
”Boost
