AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISO Creation - Modifying ISO Style Resulting in Errors (2013)
1 REPLY 1
288 Views, 1 Reply
I'm trying to generate ISOs using "FInal_ANSI-B". The problem is all the text/annotations/symbols are scaled down 25 times. When I go in to the Iso Themes tab and modify the annotation text and symbol scale to be x25 what it currently is, I get errors in ISO creation and the Live Preview doesn't resolve.
1 REPLY 1
martinTstewart_Adsk
To figure out why this is happening, first check what dimension style and test style your Iso style is using. In Project SetupIsometric DWG Settings/Title Block and Display, select the Iso style and then “Setup Title Block…” Then select “Iso Themes”. The Default Theme Dimension Style is listed there. Typically this style is “AdskIsoImperial”. Whatever style is there, open it and select Modify and check the sizes there. Adjust as needed. Same thing with Text Style.
If this resolves your question, please check this as “Solved” so others can find the answer as well.
Martin Stewart
AEC Support Specialist
”Boost
