AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
FATAL ERROR: *Urgent*
4 REPLIES 4
JohnHolder
1441 Views, 4 Replies
FATAL ERROR: Unhandled Access Violation Reading 0xfffffff8 Exception at efdd241ah
Crashes on start up.....
Repaired - no change
Re-installed - no change
When it initially crashed, I renamed the project file I was working and added "bak" to it, in case it was causing the issue.
ACad / revit / ASD all start up without an issue, it is JUST P3D I am currently unable to work.
I put in a ticket, but does anyone have a suggestion aswell?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
4 REPLIES 4
dave.wolfe
in reply to: JohnHolder
Did you clear the graphics cache:
http://www.pdoteam.com/2012/06/fatal-error-on-plant-3d-startup/
and the local data cache:
http://www.pdoteam.com/2012/03/plant-3d-startup-hanging/
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
JohnHolder
in reply to: dave.wolfe
Graphics Cache!
I backed up the directory then deleted everything inside.
Thank you very much Mr. Wolfe!
Master Yoda.
rick.ramirez
Instead of telling people to manually delete these cached files, why doesn't Autodesk resolve the actual problem? Has it even been identified? I have not been given an answer to this question and this problem seems to affect multiple Autodesk products starting with 2013 versions.
If not, is there a setting in Options that can turn off graphics cache? That way when I apply my custom profile, it gets turned off and I don't have to manaully turn it off at each end user workstation.
jason.drew
in reply to: rick.ramirez
Hi Rick,
The graphics cache can be disabled as a workaround until the issue is fixed by development. The system variables for this are saved in the Windows registry:
CACHEMAXTOTALSIZE (System Variable)
http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-F3B22467-BC93-4D91-AC10-E93EAB15...
CACHEMAXFILES (System Variable)
http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-7494F1CE-253B-42AC-BD26-10FB9E8F...
Jason Drew
Designated Support Specialist
”Boost
