AutoCAD Plant 3D Forum
Export to PCF
6 REPLIES 6
blorich
2367 Views, 6 Replies
Export to PCF
I see that when exporting to PCF I can only seem to choose by line number.  Is there a way to switch this so I can export everything by service into one file or by all selected parts?  Or by all conected parts into one file?   Same goes when generating Iso's.  The reason is we have high temp/pressure pipes that we send to Auotpipe for stress analysis and Autopipe, as far as I know, can only import one PCF file at a time and can't merge them.
If I cannot change this then I shall add it to the wishlist if its not there already.
6 REPLIES 6
quentin.contreras
in reply to: blorich
Have you tried to just change the Override Iso splitting to Split Iso when property changes? This allows you to select the other items listed.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
blorich
in reply to: quentin.contreras
quentin,
Thanks for the response, but that doesnt solve my question.  Its not exporting ISO's its exporting PCF files using PCF Export.   It forces me to choose Line Numbers only.  I would like to export by service or selected items.Capture.PNG
TomislavGolubovic
Run an Iso as you would normally, you'll still get the PCF file from however you initially selected it.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
blorich
in reply to: TomislavGolubovic
Even when I run a production ISO I have to run everything by line number, I would like to be able to choose service over line number and be able to export all linenumbers into 1 pcf.
TomislavGolubovic
Use the Quick Iso function to manually select lines. You can filter out the lines via layers for example, show/hide whatever is required or not, then use Quick Iso to select those lines. It will create the pcf and the dwg file.
Tomislav Golubovic
Autodesk, Inc.
quentin.contreras
I do understand what you are trying to do. However, there is not a selection option that will allow you to do this. The only option I see is what Tomislav wrote in his last post.
I have forwarded this also to our developers as an enhancement request, since I agree this would be a nice feature :smileyhappy:.
Also, if you would like to express to our developers why this feature is important to you, you can use the following feedback link:
Quentin Contreras
”Boost
