AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Can't get string dimension to work
3 REPLIES 3
Vitornis
376 Views, 3 Replies
I can't get a string dimension to work for my 2" lined flanged valve in my ISO's. Any ideas?
3 REPLIES 3
Vitornis
in reply to: Vitornis
Any thoughts?
jabowabo
The filter in your IsoConfig.xml is probably not set up to allow for it.  The default filter definition is:
    <Filter Name="FLValve" Value="Type LIKE 'VALVE*' AND (End1='FL' OR End2='FL')" />
 What is your end type set to on your lined flanged valve?
PeterQuinn
in reply to: jabowabo
By default, 2" and below uses the small bore theme. You can either change the limit for small bore to be smaller, or switch to the small bore theme in the iso config UI in project setup and enable string dimensions.
Peter Quinn
Senior Product Manager
”Boost
