Free tool to fix connector linegroups: http://bit.ly/1fRPDTi
For various reasons Plant 3D connectors can have the wrong or 'Unassigned' linegroup number. This will cause problems when Iso drawings are created and tracking down the connectors can be very time-consuming. This tool saves that time. The FIXCONNLG command allows users to select connectors in order to 'autofix' their linegroup assignment.
Nice tool Jason.
Out of curiosity, the connectors in your video are quite a bit larger than mine. How do you make them larger? Mine are about the size of two pixels.
Thanks Eric. The weld size can be changed here:
Make sure PLANTWELDDISPLAY is turned on. You may have to REGEN to see the changes.
I don't have a link/version available at this time.
@jabowabo; Since Plant 3D 2023 we encountered the issue for the first time, where gaskets & bolt sets automatically receive the line number of the xref line we connect to. In most (or in fact, all) cases this is very unwanted, so we found your FIXCONNLG lisp command and that's a great work around for us.
Do you perhaps know if this is still needed for Plant 3D version 2024, or did Autodesk fix this?
(we never had this issue with post 2023 versions)
@m.bevers5BJNV wrote:Do you perhaps know if this is still needed for Plant 3D version 2024, or did Autodesk fix this?
I haven't update to 2024, so I don't know.
