AutoCAD Plant 3D Forum
Aborted network evaluation due to error: eNullObjectId
2 REPLIES 2
kumarswapan64
1467 Views, 2 Replies
For Following Command Below message is giving.
Command: PLANTREMOVEORPHANFASTENERS
Command:
Error encountered while removing orphaned fasteneres.
Aborted network evaluation due to error: eNullObjectId.
Why This message is giving? Is there any problem in Model?
Tried to Rectify with Command " AUDIT"
But same message is giving.
Command: AUDIT
Command:
Fix any errors detected? [Yes/No] <N>: y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 6900    objects audited
Auditing Entities Pass 2
Pass 2 6900    objects audited
Auditing Blocks
 471     Blocks audited
Auditing AcDsRecords
Total errors found 0 fixed 0
Erased 0 objects
Please let me know why this message is coming?
Swapan Kumar
2 REPLIES 2
jabowabo
in reply to: kumarswapan64
There's an problem between the drawing objects and the database. You need to:
1. Audit project
2. Compress project
3. Purge local cache
kumarswapan64
in reply to: jabowabo
Problem is still there.....
Swapan Kumar
”Boost
