Although this may not be a BS problem, I'm posting here because I happen to be using BS2006 when I run into the problem. When I try to use the command alias "F" for fillet, I get a "Unknown command" message at the command prompt. But if I type in the full command "Fillet", it works fine. I checked the Autocad Alias Editor under Express Tools and it shows the alias "F" assigned to the "Fillet" command. I tried removing it, and then adding it back in, and saving the pgp file, but I still get "Unknown command" at the command prompt when I try to use "F" for fillet. What am I missing here?
Thanks in advance.
