AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Fillet command not working
9 REPLIES 9
Message 1 of 10
montero1
1680 Views, 9 Replies
Although this may not be a BS problem, I'm posting here because I happen to be using BS2006 when I run into the problem. When I try to use the command alias "F" for fillet, I get a "Unknown command" message at the command prompt. But if I type in the full command "Fillet", it works fine. I checked the Autocad Alias Editor under Express Tools and it shows the alias "F" assigned to the "Fillet" command. I tried removing it, and then adding it back in, and saving the pgp file, but I still get "Unknown command" at the command prompt when I try to use "F" for fillet. What am I missing here?
Thanks in advance.
9 REPLIES 9
Message 2 of 10
in reply to: montero1
Open the acap.pgp directly from CAD Manager | Customize | Edit program
parameters (acad.pgp). Is the F alias present?
Message 3 of 10
montero1
I'm sorry, how do access CAD Manager? Is it in one of the pulldown menus?
Message 4 of 10
Yes. It is not loaded by default. Use menuload and look for the
ABSCadManager.cui.
Message 5 of 10
I am curious, i can't call the command fillet or _fillet from the lisp routines I have but I can call _fillet from the command line?
Any reason other than the pgp file this can occur?
Message 6 of 10
What is even more perplexing is everytime I try to run a lisp routine calling the fillet command it blows out the pgp file altogether and I have to run a reinit?
Message 7 of 10
Undefine was run on Fillet. To execute the internal command you need to use:
(command "._Fillet" ...)
R. Robert Bell
wrote in message news:5585585@discussion.autodesk.com...
Message 8 of 10
Once again, undefine was applied to the command.
R. Robert Bell
wrote in message news:5585628@discussion.autodesk.com...
to run a reinit?
Message 9 of 10
Thanks Robert 😃
Message 10 of 10
Sorry must have posted while you were.
Thanks for your patience.
”Boost
