In the Arquitecture tab, when I insert a colum or a beam I can't modify their dimensions (height and wide for the beam for example). Any help? It just let me place the column or beam but not changing the standard.
Thanks!
Solved by davidclark70. Go to Solution.
eze, When you installed MEP if you included Architecture on the install you will have the sturctural member catalog. Use the command MEMBERCATALOG and you can choose your beam type from the catalog.
hope it helps, and hope you checked Architecture on the install....
thank you! I didn't find the button! the command worked just find! then I found the button! It is not an easy one, lol
I do not have Architectural catalogue installed, is this easy to add? I would have to go through my IT manager!
Can you advise please
Steve
