AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Soft Metric HVAC Label
5 REPLIES 5
RocksterB
622 Views, 5 Replies
I'm looking for a Soft Metric label to tag the HVAC components in an imperial unit drawing. Does anyone have this or know how to create it?
5 REPLIES 5
Joshua.Benoist
in reply to: RocksterB
Randy,
This set of YouTube videos will show how to make a Tag.  The biggest thing users run into is tag scaling with the annotative scales, but the set of 4 videos addresses the "How-To" make a tag which I think will work here.  Hope this helps,
Joshua
Link:
http://www.youtube.com/playlist?list=PL99839E19EF2CE88D&feature=plcp
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Joshua.Benoist
Hey Randy, were those videos useful?
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
RocksterB
Not in this case. I have an imperial unit drawing that contains a ductwork layout. By default, an imperial label is added desplaying the imperila unit size. I need a tag or label that will also show text in soft metric text.
Joshua.Benoist
One word (ok 2), Property Sets.
Method 1:
Use a formula property to manually convert the units.  2.54 cm = 1 inch.
Method 2:
Use a property set > property, mapped to a property data format that uses metric units.  See image.
http://screencast.com/t/PSyoi67139Xo
HTH,
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
RocksterB
in reply to: Joshua.Benoist
I used a modified version of your Method 2. I had to create addtional property sets and create a new tag. Thanks for your help.
”Boost
