AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
multiple objects
2 REPLIES 2
346 Views, 2 Replies
multiple objects
Hi!
I've a problem with the multiple objects tab. If i assign a line and a text object together, the workspace always change the home tab to multiple object tab. If i want to use any of home panels, i have to click on the home tab, and then... It's too much time for me. Can you tell me, how can i assign these object, so i stay in the home tab?
2 REPLIES 2
Keith.Brown
The knowledge article below will help you.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Solution 1 is what you need in your particular case.
in reply to: Keith.Brown
It works! Thank you!
”Boost
