I am using AutoCAD MEP 2016 but I believe that the fittings are the same and in the same location. You can use the command CABLETRAYFITTINGADD to bring up that dialog. If you switch to the electrical workspace the command should be in the build panel on the home tab.
helo
thanks for reply , but in my autocad mep 2014, all is radius elbow :((
