AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
ABS 2006
13 REPLIES 13
Message 1 of 14
290 Views, 13 Replies
ABS 2006
I'm curious about how many of the requested MV Parts were added.
13 REPLIES 13
Message 2 of 14
That problem existed back in 2003 version, and they still haven't fixed it? You have to create your own MvPart.
Message 3 of 14
Awhile back Rebecca posted a thread in this news group about MvParts that we would like to be added. Just wondering which ones made it. "jmcfaddn" wrote in message news:15546008.1111171666686.JavaMail.jive@jiveforum1.autodesk.com... > That problem existed back in 2003 version, and they still haven't fixed > it? You have to create your own MvPart.
Message 4 of 14
Rebecca doesn't work at Autodesk anymore hope that isn't any indication.... -- I support two teams: The Red Sox and whoever beats the Yankees. "Rusty McClure" wrote in message news:423b3ede_3@newsprd01... > Awhile back Rebecca posted a thread in this news group about MvParts that > we would like to be added. > > Just wondering which ones made it. > > "jmcfaddn" wrote in message > news:15546008.1111171666686.JavaMail.jive@jiveforum1.autodesk.com... >> That problem existed back in 2003 version, and they still haven't fixed >> it? You have to create your own MvPart. > >
Message 5 of 14
Is the lack of response from Autodesk an indication? "Matt W" wrote in message news:423f0562_3@newsprd01... > Rebecca doesn't work at Autodesk anymore hope that isn't any > indication.... > > -- > I support two teams: The Red Sox and whoever beats the Yankees. > > "Rusty McClure" wrote in message > news:423b3ede_3@newsprd01... >> Awhile back Rebecca posted a thread in this news group about MvParts that >> we would like to be added. >> >> Just wondering which ones made it. >> >> "jmcfaddn" wrote in message >> news:15546008.1111171666686.JavaMail.jive@jiveforum1.autodesk.com... >>> That problem existed back in 2003 version, and they still haven't fixed >>> it? You have to create your own MvPart. >> >> > >
Message 6 of 14
Rusty - Well, the team is just finishing off the last items for the coming release. They are continuing to read your posts here and have uncovered some issues in ABS 2006 based on feedback on this forum. I am sure they will be much more visible once the new release is complete. At any rate, some of the content in ABS has been deferred. The items that have made it into ABS 2006 are as follows (from the spec TOC): 1 Table of Contents 2 2 Introduction 3 3 MvParts for Tunis 3 3.1 Direct-Fired Absorption Chiller 3 3.2 Single-Stage Absorption Chiller 6 3.2.1 Units 500-800 7 3.2.2 Units 975-1350 9 3.3 Two-Stage Absorption Chiller 11 3.3.1 380-500 Tons 12 3.3.2 575 to 750 15 3.3.3 850-1150 Tons 18 3.3.4 1200-1650 21 3.4 Air-cooled Chiller 26-130 Tons 25 3.4.1 26-70 Tons 25 3.4.2 75-90 Tons 26 3.4.3 100-130 Tons 27 3.5 Centrifugal Chiller 27 3.6 Air-Cooled Condenser 17-265 MBH Vertical 29 3.7 Air-Cooled Condenser 17-265 Ton Horizontal 29 3.8 Air-cooled Condenser 301-1819 MBH 30 3.9 Evaporative Condenser 30 3.10 Gas-fired cast iron boiler 33 3.11 Modular Gas-Fired Cast-Iron Boiler 35 3.12 Solenoid Valve 37 3.13 Threaded Cap Relief Valve 38 3.14 Enclosed Spring Relief Valve 39 3.15 Y Diaphragm Valve 40 3.16 Weir Type Diaphragm Valve 42 3.17 Lever Balancing Valve 43 3.18 Y Globe Straight Balancing Valve 43 3.18.1 Sizes ½ to 2" 44 3.18.2 Sizes 2.5 to 12" 44 3.19 Y Globe Balancing Valve Elbow 46 3.20 Backflow Valve (Double Check) 48 3.21 Backflow Valve (Double Check), 2 parts: Horizontal and Vertical 49 3.21.1 Sizes 2.5-6" 50 3.21.2 Sizes 8, 10" 51 3.22 Backflow Valve (Vacuum Breaker) 51 3.23 Y Strainer 52 3.24 Exhaust Fume Hood Station 54 3.25 Ductless Bench Fume Hood 55
Message 7 of 14
Tanks for the info Peter "Peter Terwilliger {Autodesk}" wrote in message news:423f3f56$1_3@newsprd01... > Rusty - > > Well, the team is just finishing off the last items for the coming > release. They are continuing to read your posts here and have uncovered > some issues in ABS 2006 based on feedback on this forum. I am sure they > will be much more visible once the new release is complete. > > At any rate, some of the content in ABS has been deferred. The items that > have made it into ABS 2006 are as follows (from the spec TOC): > > 1 Table of Contents 2 > 2 Introduction 3 > 3 MvParts for Tunis 3 > 3.1 Direct-Fired Absorption Chiller 3 > 3.2 Single-Stage Absorption Chiller 6 > 3.2.1 Units 500-800 7 > 3.2.2 Units 975-1350 9 > 3.3 Two-Stage Absorption Chiller 11 > 3.3.1 380-500 Tons 12 > 3.3.2 575 to 750 15 > 3.3.3 850-1150 Tons 18 > 3.3.4 1200-1650 21 > 3.4 Air-cooled Chiller 26-130 Tons 25 > 3.4.1 26-70 Tons 25 > 3.4.2 75-90 Tons 26 > 3.4.3 100-130 Tons 27 > 3.5 Centrifugal Chiller 27 > 3.6 Air-Cooled Condenser 17-265 MBH Vertical 29 > 3.7 Air-Cooled Condenser 17-265 Ton Horizontal 29 > 3.8 Air-cooled Condenser 301-1819 MBH 30 > 3.9 Evaporative Condenser 30 > 3.10 Gas-fired cast iron boiler 33 > 3.11 Modular Gas-Fired Cast-Iron Boiler 35 > 3.12 Solenoid Valve 37 > 3.13 Threaded Cap Relief Valve 38 > 3.14 Enclosed Spring Relief Valve 39 > 3.15 Y Diaphragm Valve 40 > 3.16 Weir Type Diaphragm Valve 42 > 3.17 Lever Balancing Valve 43 > 3.18 Y Globe Straight Balancing Valve 43 > 3.18.1 Sizes ½ to 2" 44 > 3.18.2 Sizes 2.5 to 12" 44 > 3.19 Y Globe Balancing Valve Elbow 46 > 3.20 Backflow Valve (Double Check) 48 > 3.21 Backflow Valve (Double Check), 2 parts: Horizontal and Vertical 49 > 3.21.1 Sizes 2.5-6" 50 > 3.21.2 Sizes 8, 10" 51 > 3.22 Backflow Valve (Vacuum Breaker) 51 > 3.23 Y Strainer 52 > 3.24 Exhaust Fume Hood Station 54 > 3.25 Ductless Bench Fume Hood 55 >
Message 8 of 14
Aren't you an anchor on the local news from the Simpsons?
Message 9 of 14
saudek
When will ABS 2006 reach us who we are subscription member?
I'm impatient
Message 10 of 14
Nope, that would be Ken Brockman....
Message 11 of 14
You may have been thinking of Troy McClure, the omnipresent actor character from The Simpsons
Message 12 of 14
That is it!
Message 13 of 14
Of course, what you are really thinking about is Sideshow Bob Terwilliger, right? "The1Rock" wrote in message news:26405031.1112884898568.JavaMail.jive@jiveforum2.autodesk.com... > That is it!
Message 14 of 14
ABS 2006
so that's all Autodesk added?? Mvparts wise???
I hope not!!!!
”Boost
