AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Step out scaling and origin locations
4 REPLIES 4
689 Views, 4 Replies
Hello, I would like to revisit this because I am having problems.
I am building a 3D model in autocad from a .stp file parts and parts I built in autocad. When I stp out the file and bring it into Inventor or Back into AutoCAD the scaling of some of the parts are wrong and the some of the parts are moved to 0,0. I get the same issue when I try to import the dwg into inventor.
I can provide the files if needed
Tom
4 REPLIES 4
Steve_Bessette
It appears that there could be a unit conversion issue.  Would it be possible to provide a sample file?  This will assist in further troubleshooting this inquiry.
Steve Bessette
Support Specialist
Product Support
Autodesk, Inc.
JDMather
Type -dwgunits and hit Enter.  What does your command line say?
Do an experiment with a simple cube.
What is the results of the experiment (attach files here)?
One dwg was created using inches another was created using mm. I inserted both into a new dwg and had to scale one to the correct size. I do not know if this could cause the origin point to reset or what.
The work around for me was to create the models I needed all in one file and when I exported to stp it worked.
Tom A. Mulligan
DGE Inc. an FEV company
Desk 248.293.1348
Fax 248.293.1309
Email tmulligan@dgeinc.com
www.dgeinc.com
www.fev.com
Stop by and see us at this year's SAE World Congress
April 8-10, 2014 at Cobo Center in Detroit
FEV Booth #603
Click here to visit FEV at the SAE World Congress
Tom A. Mulligan
Desk 248.293.1348
Fax 248.293.1309
www.dgeinc.com
www.fev.com
FEV Booth #603
”Boost
