Hi All,
Good Day ! Want to know the command and steps to split a line or curve around a line. I want to show certain part of line as hidden and some as continuous. Without trimming and redrawing, is there a command that you can select object to split and line for split ? currently drawn as 1 line, I want to break into 2 lines past a certain vertical line. one is hidden and other visible or continuous. Its ok with lines sometimes but a curve or pipe with bends and radius causes nightmare.
Thanks and regards,
Yash
Solved by MoshiurRashid. Go to Solution.
