Hi all,
I'm drawing up connectors in AutoCAD which are usually all different sizes. I draw them to scale and then scale up or down as needed when showing them in a drawing. I scale them in the model workspace and not within a drawing viewport.
My issue is that I do not want the sizes of the text to be scaled with the connector drawing as I end up with text of all different sizes on my drawing. Is there anyway to stop this from happening?
David
Solved by pendean. Go to Solution.
Thanks for the info! It would seem my decision has been made for me. Option 1 seems the best way to go. But will the changes with regards to the text height be shown in the model workspace, or only when I print?
Hi again,
Thanks for the tips. I have been trying them out for the past week with some success. However I am still struggling to easily change text size on all the leader notes. Is there a way to make a style for/layer that I can put them on?
