Here's the command macro, its suppose to pick anywhere on a line insert a
circle, trim inside the circle then insert a valve in the same exact
location. I've taken out the @ symbol in the macro and it just craps out at
the trim command. I've also gone the back way where I insert the valve
first then the circle but instead of 1 user interaction like the first way I
have 2 user interactions with the backdoor way.
*^C^C_select;single;nea;\^Pai_molc^P;@;-insert;PLUMBING_cirbrk;@;$M=$(GETVAR,userr2);;0;explode;l;draworder;L;;B;trim;p;;@;@;@;;erase;p;;ortho;on;-insert;PLUMBING_V;@;$M=$(GETVAR,userr2);;
Thanks for replying
Adam
wrote in message news:6018704@discussion.autodesk.com...
Paste a copy of the macro. This was a problem in 2008 also.
