Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I suggest you post in a couple different forums that more directly access Code and Customization. I have included links here for you:
I also have a link to a Tutorial from Autodesk University that might get you started.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Hello @Anonymous,
Please let me know if my post helped you with your question.
Good morning @Anonymous
I’ve just accepted the response to your post (linked here) as a solution with the understanding that it is the correct answer.
If my response did not work as an answer, please reply to the previously linked thread so that I can unmark the solution, and we can continue the conversation.
No action is required if my response did work as an answer, however I wanted to point out that if the opportunity arises again you can also click on the ‘Accept as Solution’ button if/when relevant so that others can more easily benefit from the information. Please feel free to let me know if you have any questions or concerns!
