AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Service Pack Cannot Find AutoCad Installation
5 REPLIES 5
1034 Views, 5 Replies
I am trying to install a service pack. the file is...
autocadmap3d2011lockedx86sp2
I click to install this application service pack and this error appears...
THe update could not be installed because the expected autodesk product could not ne located on your computer. Make sure that you are using the correct update for the product.
I believe I have the correct file for the product but I do not know were to go from here.
Thank you for the help.
5 REPLIES 5
thepworth
looks like you might have a 32-bit update and a 64-bit install???  Check if you have the .exe for autocad under Programs or Programs (x86) - x86 is 32-bit.
in reply to: thepworth
Thanks for the reply, though I do have a 64 bit install and I tried the 32 bit just for giggles, that did not work.
thepworth
so, did you try the 64-bit service pack - http://images.autodesk.com/adsk/files/autocadmap3d2011lockedx64sp2.exe ???
That did the trick, though I didn't even need an update, ah well, thanks for the help. issue solved,
I feel like Pinky right know. Ha
Tags (1)
thepworth
If it ain't Baroque, don't fix it...
”Boost
