In the last 24 hours I have lost right-click menu options such as deselect all, Pline edit, move/copy/erase, node editing, insert vertex, convert to arc/line. It also will not let me delete objects using the keyboard 'delete' button, and once selected I canot deselect objects.
Solved by nwray. Go to Solution.
Not sure about all of the issues, but check your selection mode. Under the OPTIONS menu, go to the "selection" tab, and make sure that the "noun/verb selection" box is checked. This could help your issue with being able to delete items using the delete key. I have seen this setting get changed at random sometimes.
For the other issues, I'm really not sure why the commands are disappearing from the right click menu. Are you able to add them back in manually?
Norm
I have successfully re-activated the noun selection option (it was un-ticked) this has also re-activated my right-click menu options, so they are all back and working!! All I need to know now is what changed the setting in the first place!! or is it just AutoCad being AutoCad and random!?
Thank you,
Anne
Hi Anne,
Glad it worked! It is a system variable, and I have had issues with it sometimes changing on it's own. This variable and FILEDIA seem to change by themselves from time to time; I've never had anyone explain exactly why.
Norm
