When I drawing a line and I try to use the numbers for its length not only it doesnt work but it wont allow me make the endpoint forcing me to cancel it
Make sure you are typing in the same UNITS as you have specified for the drawing. If you have set UNITS to DECIMAL - then you cannot use a foot mark (123'). If you are trying to type in the distance and you see the dynamic box turn red then it means you are trying to type incorrect units in the box.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
