We have a drafter who's Map 3D 2013 Drafting Settings dialog box is giving him a pop up that says "Please enter an integer from 1 to 30". He is able to set osnaps and others thru quick keys and other methods, but going through the dialog settings dialog box is generally the easiest way to go.
If anyone knows what is happening or how to fix it, please let me know. The only button that seems to work is the cancel.
Michael.
Solved by olivier.eckmann. Go to Solution.
Hello
Just an idea :
Could you check the SNAP Tab and its X/Y values ...
Try to disable SNAP with F9 ?
Bye, Pat
Patrice BRAUD
From the Help menu:
http://docs.autodesk.com/CIV3D/2012/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4f1d.htm
This describes osnap settings.
HTH,
Susan H
this message is due to a wrong parameter, but not in OSNAP tab, but in QUICK PROPERTIES Tab.
It's the number of rows in in the quick properties palette wihich must be between 1 and 30 .
Even if you are on OSNAP tab, when you click OK, all values in ALL tabs are verified.
Olivier
Type "GRIDMAJOR" then set it to 100 or any number from 1-100, I used 100 and it works great. Thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
