AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Nation Map Seamless Viewer help
3 REPLIES 3
millermccoy
469 Views, 3 Replies
I downloaded and unzipped the files and I've assigned a Zone.
How do I get the aerial into Civil 3D 2013?
2015 Civil 3D
3 REPLIES 3
what type of files have you downloaded?
If they are standard GIS-files then you would have the option:
  • command _MAPCONNECT
  • or if it's raster-images I would preferre the usage of _MAPIINSERT.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
.dbf
.idx
.prj
.shp
.aux
.xml
.html
.txt
.adf
.dir
.dat
.nit
don't know which file to select under mapiinsert command
2015 Civil 3D
I wrote that you can use _MAPIINSERT for raster-images, well, I meant colorized raster images), sorry for beeing not clear enough.
Within your list I see:
  • SHP that can be connected with command: _MAPCONNECT (btw: delete the IDX-file before referencing the SHP into your Map3D-session).
  • ADF, also this can be connected with _MAPCONNECT (it's raster, yes, but not colorized raster, it's a type of elevation-model). You can look to >>>this page<<< for how to use it.
  • I don't know what's behind DAT or DIR or NIT, but the others have no direct data, just info like projection-systems, index-file, ...
- alfred -
Alfred NESWADBA
”Boost
