I have been trying to import .fbx to autocad with materials but thus far have been only able to get mesh visible. The fbx is exported from Autodesks Remake and it should be made for Autocad. The mesh size is reasonable (20mb). Any ideas why materials are not visible?
Funny fact: The materials are shown in Microstation when I import the fbx into it, so I guess the material properties should be included into the file.
Really hope someone can help me with this problem!
have you verified that the FBX file really contains materials? And are you referring to just material or textures too?
Which version of Map3D do you have? Which service pack is installed on top of it. And what operating system is your workstation running?
If you can share the FBX model then we can look on our systems to get it working.
- alfred -
Hi!
Here is partial FBX of my model. Hopefully you can get it visible in autocad.
And the answers for your questions.
MAP 3D 2016 version: R20.1.107.0.12
OS: Windows 7
I am pretty sure that the file contains required materials since it opens up neatly in Microstation and it might be that I am talking about textures.
Yes, I can see the material in FBX-viewer, in 3DS-Max as well as with Navisworks.
But sorry, I can't get it imported into AutoCAD too.
What will you do with the object on AutoCAD, what is the job to do?
- alfred -
Hi!
Thanks for confirming that it cannot be imported to Autocad. Since I am working with infrastructre and our main tool is, at least for now, Map 3D the FBXs created from Remake would make a great addition to our work flow. We are still in test phase what this can be used for and especially how. Do you have any idea if it could be opened with Civil 3D?
Sorry, no, not any AutoCAD based product (so AutoCAD and verticals like Map3D, Civil3D, ...) seems to import the material texture.
Look to Autodesk InfraWorks (>>>click<<<), maybe that is a tool you like and which helps for your work (and yes, this can add FBX incuding textures.
- alfred -
